I think i blew a fuse. plz help. - FirebirdV6.com/CamaroV6.com Message Board
  • I think i blew a fuse. plz help.
    It appears i have shorted out my ac power adapters in the car. neither the cigarette lighter works nor the accessorie power jack works. I had a 3 way splitter hooked up to the accesorie power plug and one of the wires had come unhooked. i tried to stick it back in it. there was a flash (sparks) and then both my little blue lights and my fuz buster (plugged in the 3 way) stopped working). i tried to use the cigarette adapter but that doesn't work either ... i am hoping its a fuse and easy to fix. let me know which on (and location) to look for. thanx.
    Ummad!<br />2k pewter maro M5. 160 thermo, WhisperLid w/K&N Filter, Jet PCM Stage 2, Free Ram Air, Air Silencer Delete (purchased already and) waiting to install manual fan switch, air/fuel ratio guage.
    on the drivers side to the left of the light control panel, down a little bit on the side of the dashboard is where your fuses are that you will need to replace, if it is only the HVAC fuse, then all you need is one new fuse *not sure the size* ill check when im back out at my car, but its easy to do and fuses are cheap.
    Dave:
    00 Supercharged Camaro - RIP
    97 Turbo Camaro - Sold
      thanks dude .. i figured thats where the fuse for it will be .. i was wondering if someone knew exactly which one do i need to replace .. the power rating is on the fuses so i can figure that out .. plus yea they are cheap ... lemme know if you figure out which one it is...
        on the backside of the panel that comes off, tells you what each fuse is. just take a look at it, its easy as pie.
        Dave:
          k. i'll check it out during lunch .. thanx for the assist.
