Instructions on doing a fan switch for a 3.4 Camaro/Firebird - FirebirdV6.com/CamaroV6.com Message Board
  • Instructions on doing a fan switch for a 3.4 Camaro/Firebird
    I figured I would share this with other 3.4L camaro/firebird owners.
    First you have to locate and remove the cooling fan relay in the fuse box under the hood. After that all you gotta do is run a wire from a switch into slot A of your cooling fan relay (just as a safety measure put a 10 amp fuse somewhere between the relay and the switch) and take another wire and run it from a ground to the switch. Finally put the relay back into place. The fans should come one when the switch is in the on position.
    1995 3.4L Camaro Purple/Yellow<br />Moroso CAI,Jet Stage 2,180 thermostat Flowmaster,Fan switch Mod,Fog Light Mod,Wings West ground effects,RK Sport \"Sport wing\",Yellow racing stripes,Autometer Gauges in pod: Air/Fuel Ratio,Water temp gauge,Voltmeter
    Does this way cause an SES light
      Nope. I did it like 6 months ago and still no problems.
