When I press the release button for the back hatch it does not release. You can hear the motor run, but it never releases. Anybody else had this problem? Any way to fix it?
hatch release problems
mine doesnt release either, ever sence i got the car. i never listined to see if i could hear the motor though. hopefull someone will know.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Originally posted by 99pewterv6:
TRY THIS1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Two things come to mind that would be easy to check. First, I think (and its been about a year since I worked on the hatch release) the actuator on the release grounds right there under it. Make sure that the wire hasn't come loose or is broken. Second, The parking brake has to be on for the release to work, there is a small switch on the parking brake lever, maybe that has broken or come loose.
Otherwise, I would suspect the relay or the actual actuator on the release mechanism. Easiest thing to do would be to disconnect the electrical connector, use a voltmeter and have a friend hit the button. If you don't get any voltage it could be the relay/parking brake switch/etc.1994 Arctic white, 3.4l, 5spd<br /><br /><a href=\"http://www.cardomain.com/id/montytrmpt\" target=\"_blank\">http://www.cardomain.com/id/montytrmpt</a>
Originally posted by montytrmpt:
The parking brake has to be on for the release to work...96 Teal Firebird<br />Colchester, Essex, UK<br /><a href=\"http://www.centrestage.free-online.co.uk\" target=\"_blank\">www.centrestage.free-online.co.uk</a>
