can anyone give me step by step instructions to replace the oil pan gasket. how hard it would be for 2 people to do. And how long? thanks
oil pan gasket again
I believe you cannot do it with the motor in the car. Unless you can unbolt the motor mounts and lift the motor up so you can pull the pan off. I'm not sure, I havent done it.<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
you would have to support the engine w/ a cherry picker and unbolt the motor mounts and k-member but its been done1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
