Calling all Jet Stg. 2 Chip owners.... - FirebirdV6.com/CamaroV6.com Message Board
  • Calling all Jet Stg. 2 Chip owners....
    When installing the chip, do you just follow the instructions and thats it, or is there some other little trick to do as well. I did a search and didnt really find much, except for one thread that said something about a pink wire being splices into something.....did you guys just follow the directions and thats it or what??
    99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>
    <blockquote>quote:</font><hr>Originally posted by 99firebirdconv.:
    except for one thread that said something about a pink wire being splices into something<hr></blockquote>
    Maybe i have a totally diff one, but i didn't have to splice jack-****...all i did was unscrew the wire harness, stick the chip in the middle and screw it back down...maybe your talking about a different chip alltogether
    1999 Chevrolet Camaro Z28<br />1987 Buick Grand National
      your should be very similar to kidinthehall's
      in fact, it should be physically exactly the same
      This will take you 10 minutes, and will save you a lot of headache.
      Before I start, I do recommend deviating from the instructions a bit (as in not removing the negative terminal). I will not take any reponsibility for any damage to your vehicle by following these instructions. I did this, and it worked great. If you are nervous about frying your computer, take out the terminal. But when you reconnect it, do so in one motion, and do so quickly. I fried my battery, so the second time I installed the chip, I did not disconnect it. Now on to the install process.
      1. Open hood
      2. Look on drivers side of engine bay, near the front. You will see two breaker boxes. Open them both. Now remove PCM BAT & PCM IGN. Set them aside.
      3. Passenger side, top corner of engine bay. You will see two very wide plugs w/ lots of wires going into a metal box. That is your computer. Remove the bottom plug with a socket. Note that the screw will not come all the way out, unscrew it until it seems like its not coming anymore, and then pull out the plug.
      4. There will be a red gasket on either the computer or the plug. If it is on the computer, take it off and put it in the plug. Make sure to push it all the way down with a screwdriver, or a key.
      5. Get your jet chip. Look at the female side. You should see only one gasket, and it should be lower than the black plastic edge. If not, attempt to remove it to make sure there are not two (esp if you bought used). If there is only one, push it down w/ a screwdriver or key.
      6. Now get the extension to the jet chip. Screw it in by hand all the way. Don't bother tightening, that is unnecessary.
      7. Now plug in the jet chip. To align it properly, make sure your plugging the female side(holes) into the computer. Also make sure the "hump" is on the bottom & the sticker on the side that says "Jet" is facing you & upside down. It should go in with little force. If you are having a time getting it in there, take it out and make sure that you have it aligned correctly and make sure there are no bent pins. Do not shrug off bent pins, if they come in contact with another -- especially if it is a ground or power pin, your going to regret it when you start the car (if they come in contact now, no big deal, no power going to the pcm w/ the fuses out).
      8. Now plug the plug into the jet chip. You may have a little problem doing this becuase its wires are pretty short and because you may have clearance issues with some hood hardware. Just very gently put the right corner of the plug into the chip (just a little bit, you don't want to be hitting pins yet), then lower the other side in. It too should go in with little effort, so if it gives resistance, check alignment and for bent pins. It also will not go all the way down because of the screw, so tighten that snug (but not iron grip, hand tighten then a couple turns of the socket wrench is fine).
      9. Replace fuses
      10. Start car... It might stumble a little bit, give it some time. No SES lights should come on. Drive around and be happy. :)
      there you go [img]smile.gif[/img] , later
      2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
        so pulling the fuses out instead of disconnecting the batt is safer/better???
        either way, no power would be going to the pcm???
        it seems like pulling those fuses is a lot less hassle... is there an easy way to f$#@ that up?
        is there an easy way to f$@# up taking hte batt cables off?
        chip goes in friday....
        thanks
        - \"So you have something to look at when you\'re talking to \'em\" - <br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=296916\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=296916</a>
          I want to make clear one thing, if you follow these directions & fry your car, I'm not responsible [img]tongue.gif[/img]
          However, I installed & uninstalled the chip several times by simply pulling PCM BAT & PCM IGN.
          I think its easier than the battery cable, which I had trouble getting back on. If you do decide to disconnect the battery cable, when you reconnect it, it will spark. Ignore them & hook the sucker up, don't let it slip all over the place & mess w/ the power in the car.
          Only disconnect the negative (black) terminal remember.
          Either way, you should be fine.
            <blockquote>quote:</font><hr>Originally posted by strobhen:
            I want to make clear one thing, if you follow these directions & fry your car, I'm not responsible [img]tongue.gif[/img] <hr></blockquote>
            My attorney says you are, (johnnie cochrain). And your gonna pay out your *** !
            :D :D :D [img]tongue.gif[/img]
              I used Strobhen's instructions with no problems. That picture from the Jet instructions will screw you up.
              [ September 05, 2002: Message edited by: AMinor65 ]</p>
              <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
