Sounds like a platinum plug - they are all white. Describe what you mean by "looks bad". A typical plug pulled from an engine without severe misfiring problems or valve-stem seal or ring problems will look off-white to tan.
If the gap is too large, that can cause occasional misfires and make the vehicle run poorly.
<blockquote>quote:</font><hr>Originally posted by zccop2001: a little faint smell of something under the hood, im guessing the wires have a "breaking in" smell? <hr></blockquote>
Just make sure it isn't from the wires burning because it is now touching a manifold or hot engine surface.
