My Camaro has a problem with while it is idling. It kinda surges in between 900 and 600 rpm's. The car also shakes really bad while in drive. If I ake it out of drive the shaking stops, but it idles that same way. Any suggestions on what might cause this? Thanks in advance.
Surging Idle
Just a wild guess I would say it sounds like your plugs/wires/or coil pack(s) could be worn or fouled up. Or at least thats what I would check first. Make sure your wires & your coil packs are all good and all your sparkplugs aren't fouled. It's a good practice to keep up on too. To do that either read up in your chilton's manual (which I recommend to everyone by the way) or search some other posts. I know i've mentioned how to properly check wires/coil packs a few times now. Good luck
[ September 01, 2002: Message edited by: Ted ]</p>
Run diagnostics on your throttle position sensor (TPS). I think it runs around .5 ohms if you have acess to a tech II. And yes, a tech II will diagnose your car even though it's a 3.4.Teal 94 Camaro 3.4 Liter<br />Transgo stage 3 shiftkit, Shift module, corvette servo, SLP cold air induction,3.42 ring and pinion, Heavy Duty Posi LSD, Flowmaster exhaust, NX, blackouts
Take out the IAT sensor and clean the port and the sensor itself. If that does not help you might need a new sensor. The IAT is mostly the cause of a surging idle.2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
<blockquote>quote:</font><hr>Originally posted by toast:
Take out the IAT sensor and clean the port and the sensor itself. If that does not help you might need a new sensor. The IAT is mostly the cause of a surging idle.<hr></blockquote>
I meant to say IAC not IAT. I always get them mixed up.
:mad:2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
What does IAC stand for...will make it easier to find in chilton's [img]smile.gif[/img]1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
