Surging Idle - FirebirdV6.com/CamaroV6.com Message Board
Surging Idle
  • Surging Idle
    My Camaro has a problem with while it is idling. It kinda surges in between 900 and 600 rpm's. The car also shakes really bad while in drive. If I ake it out of drive the shaking stops, but it idles that same way. Any suggestions on what might cause this? Thanks in advance.
    \'94 3.4 Black Camaro
    Just a wild guess I would say it sounds like your plugs/wires/or coil pack(s) could be worn or fouled up. Or at least thats what I would check first. Make sure your wires & your coil packs are all good and all your sparkplugs aren't fouled. It's a good practice to keep up on too. To do that either read up in your chilton's manual (which I recommend to everyone by the way) or search some other posts. I know i've mentioned how to properly check wires/coil packs a few times now. Good luck
    [ September 01, 2002: Message edited by: Ted ]</p>
      I have replace the plugs and wires twice now with no change. I have accel 8mm wires and AC Delco Rapidfire plugs.
        Run diagnostics on your throttle position sensor (TPS). I think it runs around .5 ohms if you have acess to a tech II. And yes, a tech II will diagnose your car even though it's a 3.4.
        Teal 94 Camaro 3.4 Liter<br />Transgo stage 3 shiftkit, Shift module, corvette servo, SLP cold air induction,3.42 ring and pinion, Heavy Duty Posi LSD, Flowmaster exhaust, NX, blackouts
          Where can I pick up a tech II and how much do they cost?
            Take out the IAT sensor and clean the port and the sensor itself. If that does not help you might need a new sensor. The IAT is mostly the cause of a surging idle.
            2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
              I had a problem with my idle last year, it surged REEEEL bad! Turned out to be my IAC Sensor. I'm not sure where the 3.4 IAC is located though.
              Marc
                <blockquote>quote:</font><hr>Originally posted by toast:
                Take out the IAT sensor and clean the port and the sensor itself. If that does not help you might need a new sensor. The IAT is mostly the cause of a surging idle.<hr></blockquote>
                I meant to say IAC not IAT. I always get them mixed up.
                :mad:
                  even if you haven't thrown a service engine light, check your O2 sensors. I had the SAME problem and when I got it replaced, problem stopped.
                    I replaced the O2 sensors not too long ago. I'll try cleaning the IAC thing too. I'll check the Chilton's manual to see where it is. I'll let you know if it helps.
                    [ September 03, 2002: Message edited by: Black3.4Camaro ]</p>
                      Cleaning the IAC sensor didn't help any.
                        What does IAC stand for...will make it easier to find in chilton's [img]smile.gif[/img]
                        1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
                          Idle Air Control
                            I cleaned my IAC about six times, but replacing worked MUCH BETTER! Go to Autozone, it costs about $26.00 there.
                            Marc
                            • 187shark
                              by 187shark
