Eeeek,
I've been overtaken by a Mercedes van.
I have a severe power loss meaning I can't drive at anything past part throttle, it makes all the induction noise but don't go faster than 70mph, also slow off lights (fuel starve ?)
Did run out fuel other day (as no warning light fitted as standard), maybe blocked fuel filter ?
tried a bit more - changed fuel filter, no difference. if you hold throttle open under hood car won't rev past 4000 (like limiter cutting in) and if more throttle engine slows down !
Also strange problem, for half hour other day battery showed no charge and went down to 10 volts but cured itself whilst driving - don't know if connected. Servicing is tricky here as not many people have plug in test gear.
Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...
Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...
