The other day I was driving and turned the radio down to hear this aweful sound commin from the back trunk area. I though it was the usual squeaking of a loose antenna. I tightened it and sure enough the base is loose. How do you tighten it, also could there be a seal broken on it? Thanks.
antenna base....
Are you saying the nut on top of the Bezel which is on top of the quarter pannel is loose?
It should just be a matter of tightening down that nut to fix your problem. The only thing is, I dunno if that is something you can get ahold of with a normal wrench, I haven't looked at my car in months (Winter) so i don't remember what it looks like. According to the Service Manual, there is a special GM tool for tightening it.1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
I fell for that one too.
I made a "special wrench" from a cheapy
stamped steel wrench like the kind you get with a new bike.
After cutting the slot large enough and filing until it fit snug,I put it on workbench next to 13MM open end and it was same.
So much for the special wrench.
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...4 weeks ago
