How to tell what kind of thermostat is in car? - FirebirdV6.com/CamaroV6.com Message Board
  • How to tell what kind of thermostat is in car?
    I'm not sure if the thermostat in my car is stock or an aftermarket one. When I bought the car it came with some mods, and I'm not sure if this is one of them. The temperature gauge gets to about 185-190 degrees and stays there, never moving once it's warmed up.
    Is there anyway to tell what kind is in there aside from taking it out and checking?
    *SOLD 9/4/05*<br />1998 Navy Blue Metallic Camaro M5<br />-Flowmaster cat back<br />-Accel Ignition<br />-K&N Air Filter<br />-Hurst Shift Knob<br /><br />Currently vehicle-less at Ohio State :(
    well, i dont have a low temp thermostat, but if your car had a low temp thermo., like 160 degrees or something, i would expect it to stay around that temp. i heard that our cars stock thermo. is set at 190's range, so that also gives me a hint.
    2001 camaro v6 red convertable<br /> ggotta go fast... I GGOTTTA GO FFAST! CCANT HEELP MMMYYSSELLLF<br />pics:<br /><a href=\"http://www.cardomain.com/id/darkthoughts5000\" target=\"_blank\">http://www.cardomain.com/id/darkthoughts5000</a>
      its still hard to tell, even if you did have a low temp thermo it would stil get above 160 or 180 or whatever. i have a 180 but it doesnt always stay that low. i suppose you could warm up the car and see at what temperature you can feel the coolant flowing through the tubes
      Visit My F-Body Page
        You have a 98. There is only 3 bolts to take out and some paper towel to catch the coolant. Get a thermometer and some heated water, and test it. That is probably the only to tell for sure.
        Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
