I dunno why but lots of electrical stuff in my car is going wrong. It will be kewl is someone can help me find out whats wrong so I can try fixing it.
First problem is that left brake light don't turn on when I press on the brake pedal. I know its not the light bulb because the tail lights do turn on if I turn the headlights on. It just dont do anything when I press on the brakes. I need to get this fixed before I get pulled over...
Second problem is that I have trouble starting up my car sometimes. Sometimes when I turn the key to the ON position, electronic stuff turns on and off and on and off(Keeps doing that really fast and all the electrical stuff finally tuns on). Then when I twist the key, the engine doesnt crank at all sometimes. so I will pull the key back and try again and again and the engine finally starts running. I'm thinking that ignition thing that you put your key in is going bad but I'm not sure.. Anyway to check this?
The final problem is that the brake and traction light sometimes blinks. And it goes off when I press on the brakes. Also, the ABS INOP light is on all the time.
Any info that would help me with these stuff will be appreciated. Thanks all!
[ November 17, 2002: Message edited by: ChronoGN ]
[ November 17, 2002: Message edited by: ChronoGN ]</p>
