ABS INOP - FirebirdV6.com/CamaroV6.com Message Board
ABS INOP
  • ABS INOP
    My new issue lies in my ABS INOP light. On cooler days (50-60 degree) if I don't let the car run for like 5 minutes before going, the light will pop on. If i stop, turn the car off, wait 30 seconds, then restart the car, the light goes away, never to return until the next cool day. Is there some reason is does this or is my car just acting wierd?
    2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
    Checked brake fluid, etc. All brake lights work fine, and the brakes work great. It has done this intermittenly. Brakes have been replaced about 2-3 times since this started so I don't think it is gonna be somethign to do with my pads and rotors...
      also check to make sure all the rear lights work at the back - I know it sounds weird, but theres some connection
        Also, take the grounds off the core support and the pass. inner fender. Usually the paint under the ground wires keeps them from grounding correctly. Sand off the paint and put the grounds back. Good luck
        1999 Silverado- Bagged, colormatched and rollin on stock chrome 16\'s<br />Make love not war, hell do both, get married
