My 99 which has never had a problem resently developed a stumble in idle and acceleration. I replaced the plugs, while does idle smoother it didn't solve the problem. This stumble does not occur all the time, just randomly in idle and/or under acceleration. Could this be a sensor or something else. i don't believe its misfiring although it feels like its retarding the firing to make this stumble. Why is there no SES light when this happens? Since there is no light I'm guessing its not a coil pack but rather a sensor miscommunicating. I've heard the sensor in the air intake(name has left my mind as I type) can get dirty from K&N fluid - could that cause this problem?
Engine Stumble - sensor - no SES light! HELP
mine did the same thing for a little while. it got really bad and throwing errant codes out. like bad crank sensor and stuff. I put on some new wires and plugs and ran some sea foam through it. and it fixed it. Mine was mostly when taking off from a dead start. felt like the tranny slipping.Pain heals, chicks dig scars, and glory is forever.<br /><br />------------------------------<br />1997 Red Firebird with T Tops<br />Custom 3\" cold air intake <br />K and N filter<br />!maf<br />flowmaster 80 series catback<br />Accel 8.8 300+ spiral ferro wires<br />Bosch 2X platinum +4 \'s
im thinking you Mass air flow senor, or your throttle posion sensor
could be bad O2 sensor.www.turbov6camaro.com
1997 3800 Series II Camaro
im think its your TSP or MAF, some things dont throw codeswww.turbov6camaro.com
