A/C Sounds like NOS purge - FirebirdV6.com/CamaroV6.com Message Board
  • A/C Sounds like NOS purge
    First off...in the topic I could have said nitrous purge but NOS is shorter
    Anyways check it out guys. If you have an older F-bod...say 99 and older (tested on my buddy's 98) and you turn the A/C on, it'll make a low bang sound, BUT WHEN YOU TURN IT OFF, it makes a hiss sound which is similar to a nitrous purge. It's kinda loud (once you turn the radio off) and it sounds cool from the outside. :D
    Does your a/c work if not you might have a vacuum hose off or leaking. Theres on leaking on my car now so the top half of the a/c doesn't work and you hear that hissing sound somewhere in the a/c compartment. I have to track it down and fix it.
      nah A/C works and blows REAL COLD air so there is no problem. I brought it in (when under warranty) and they told me it's normal. Damn biatches too lazy to actually try and fix something
        Yeah, mine does the same thing. Not really loud, I would say more like just barely audible, but its there.
        Jared W. Drummond<br />jdrummon@vt.edu<br />1997 3.8 Firebird M5<br />-----------------------------------<br />*Flowmaster 80 Series Muffler* *SLP Cold Air Intake* *Zexel-Torsen LSD* *1-Piece DS* *Eibach Pro-Kit* *Removed MAF Screen* *Manual Fan Switch* *Mobil 1 Oils*<br />-----------------------------------<br />*Pioneer Premier DEH-920R Headunit* *Orion Cobalt 6 1/2\'s* *Sub Stealth Box w/ Alpine SWR-1021D* *Kenwood 728S Amp for Sub*
          AC vents and ducts are vacuum operated. It's normal.
