valves - FirebirdV6.com/CamaroV6.com Message Board
valves
  • valves
    will it give me more horse power if i make my valves oversized??? do i have to oversize both or only the intake valve????how many octane would i need for a 11.0:1 compresion and where can i buy those pistons?? by the way its a 3.4 thank you guys
    11:1 on a 3.4 [img]graemlins/omg.gif[/img]
    94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
      with the right cam and programing, it would beable to run on 93 octane
      my red camaro 3.4 had 10.2 and ran fine on 89 octane
        You can do one valve or the other or both.
        Do you know if you need them or not?
        A realy good port and polish would be the only way to make use of bigger valves.
        The turbo calc says 93 will work on a 3.4 with 11:1 c/r.
        Mainly becasue you have the low V.E. of a 60-v6.
          I have Ross flat top pistons which give a 10:1 compression and I run 93 on mine. Keep in mind that you can save money by going with flat top pistons vs. domed.
