Help! - FirebirdV6.com/CamaroV6.com Message Board
Help!
  • Help!
    installinga remote starter/keyless entry unit and i m stumped as to where my starter wire is, is it a thicker pink wire? also, where do i tie into the tach wire? the previous owner had a keyless entry remote start setup and di da hack job of removal, im just trying to find where the black tape was on the old wires and hook up my new box like that! any help woul dbe appreciated, but pics would help that much more!
    Black 1995 3.4L V6 \"<b>THE BLACKBIRD</b>\"<br /><b>Performance Mods </b> K&N Fipk, Hypertech Underdrive pullies, Accell Coilpacks, and wires, rapidfire plugs,180 degree thermo, 1LE Tranny Mount, Z28 Catback W/crome tips B&M Ripper shifter<p><b>Appearance mods</b> 2 1/2% Limo tint all around, Blacked out taillights, turn signals, and side markers, red PONTIAC rear Inlay, 98+ style centerplate bird and graphic<p><b>Stereo System</b>Panasonic Cqdf 800u head unit, 2 MTX thunder 280 amps bridged, 2 Cerwin Vega AI 12\'s on the rear deck, 6x9\'s in the rear sail panels, Monsoon Door panels With Memphis Audio 6.5\" Coaxials and tweeters, 1 farad EFX cap.
    I don't know if it's the same for a 95 but I have some info for a 2000. On a 2000 camaro the heavy gauge wires are as follows:
    • Red= 12 volts
      Pink= Ignition
      Orange= Accessory
      Yellow= Starter
    Now for the tach on a 2000 camaro. Look under the hood on the passenger side. Your pcm has two big plugs right? Well the tach wire is on the top plug towards the right. It is a white wire and it is on pin 54. You should see 54 right above where the wire goes into the pcm.
    This info is for a 2000 Camaro so I don't if it's the same for a 95. [img]smile.gif[/img]
    2000 Camaro 3.8 v6 M5
    Flowmaster 80 series muffler, B&M ripper shifter, SLP grille
      I think im on my own as far as tach wire goes, you guys got a bcm in 96 i think? any 3.4 peeps with ideas?
      • 187shark
        by 187shark
