i hav a 95 firebird 3.8l and the other day my friend sprayed carborater and choke cleaner in the intake and ever since then the car stumbles and backfires through the intake it idlos perfect until u put a load on it i have new wires on it and new plugs i checked the pluggs twice to make sure i didnt foul out a plug but some poeple are saying it could b a clogged injector or a 02 senser can someone pleae help me the service engine soon ligh keeps blinking to.
HELP!!!!!!!!!!!!!!!!!!
Take the car to Autozone and have them scan the computer. It's free. They will be able to tell you what codes triggered the SES light and what you can do to fix it.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
cylinder two misfire comes from one of 4 things -
the spark plug, the plug wire, the coil pack, or the ignition module. check them all.
from what you said, seems more likely to be the coil pack. if the ignition module goes, usually all the cylinders will end up going.
Tap your catalytic converter too, it MAY be on its way to a clog. At first I only had 1 cyl start to misfire, then they all went. just something to watch for.2011 Camaro LS 6M, in black.
HEY WOULD IT BE A TBC SENSOR OR A MASS AIR SENSOR BECASUE I CHECKED EVERYTHING AND THE PROBLEM DIDNT OCCURE UNTIL THE CARB CHOKE CLEANER WAS SPRAYED IN THE INTAKE WILE THE CAR WAS ON AND HE WAS REVING IT UP WHILE SPRAYING THROUGH THE INTAKEcold air intake <br />80 series flowmaster<br />no cat (straight pipe)<br />rebel flag
Originally posted by hockeyman:
Better hope it wasn't your MAF you screwed up. Them things are expensive!
that waht it sounds like to mewww.turbov6camaro.com
1997 3800 Series II Camaro
i think you confused some
its "TPS" not "TBS"
the one buy the air box is the IAT (intake air temp)
the MAF is in the TB
the TPS is on the left side of the TBwww.turbov6camaro.com
Originally posted by bigCountry:
couldnt i get those sensors off a 95 firebird at a junk yard cheaper? and this isnt something that is going to leave me on the side of the road until i get it fixed is itwww.turbov6camaro.com
thanks lol i confused myself with that one to if its a sensor doing all of this which one could it be when i went to autozone to get the car scanned it showed up tps i thinkwww.turbov6camaro.com
