what does a maf sensor do when it goes bad???
HELP!!!!!!!!!!!!!!!!!!
i justed Sea Foam to clean out my intake/tb and i ended up killing a coil. replace your plugs, then if that doesn't work, check your coils, and if that doesn't work then look into the MAF.Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
i think is a maf i unplugged it a drove it around the block and the car didnt stumble at all i drove close tonormal but it still backfired through the intake alittle and when i plugged the maf back in the problems came backcold air intake <br />80 series flowmaster<br />no cat (straight pipe)<br />rebel flag
If they scanned your car and it said it was a TPS, go to autozone to get it. Ask for part number TPS144, it cost's $49.99.
I'm not completely sure what the symptoms of a bad MAF would be, but I know it's not good, and I know you don't want to hear how much it cost's. ;)sigpic
Or, you can buy This Throttle Body on ebay. Not sure if everything is in working order though.sigpic
i im starting to it frustrated the car sounds like u put a hole bunch of fireworks under the hood when when u giv it alittle gas it goes pop pop pop pop in the intake could it b an ignition coils how do i check if there bad can i tell by looking at itcold air intake <br />80 series flowmaster<br />no cat (straight pipe)<br />rebel flag
yea it wouldnt be a timing thing would it when the engine cools ill check all the pluggs again and make sure ther not loose but theres like no power if i smash the pedal the car justs stalls and backfired through the intake really badcold air intake <br />80 series flowmaster<br />no cat (straight pipe)<br />rebel flag
HERES ALITTLE SONG I WROTE: on the first nite in the titty club we was checkn out all the chicks there was black ones white ones an breunetts and blonds look at the size of that redheads tits the first girl i tiped was flat as hell but had an *** sent from god i was horney an even though i wasnt rich i was tippn like a son of a ***** say hav u ben to a titty bar with 200bucks it feels good to b out with my friends in the titty club u can b a good cheer because there aint nothn better than tittys and beercold air intake <br />80 series flowmaster<br />no cat (straight pipe)<br />rebel flag
Um if your spark plugs are white, I forget what causes that (lean condition??)
Anyways start with replacing the pluggs. If they are white they needed replaced anyways. That may solve your #2 cyclinder miss. And I'd think if your MAS was bad it could be causing your lean condition, causing your plugs to go bad.
Now why in the world did I see an Okie song about tittys and beer at the end of page 1 when I thought you were desperate to find a fix on this message board?? I couldn't believe my eyes without laughing so hard. From what I can tell you and your friend had too much time spraying carb cleaner in the intake when it isn't even a carb to begin with. Good Luck ! lolBlack \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
alrigh i took my car to the shop to get it looked at and said it was a coil pack so instead of payin ghtem 200dollerrs to put the thing in i drove the the local parts store and got one for 18dollers put it in and it runs almost perfect but the car just seems justs a littlebit sluggish and will kinda cut out going up hill and when im at a stop and i punch the gas the car will like take a second then the tires will spin so mababy tps sensor or an injector needs cleaning ??cold air intake <br />80 series flowmaster<br />no cat (straight pipe)<br />rebel flag
