aluminum driveshaft - FirebirdV6.com/CamaroV6.com Message Board
aluminum driveshaft
  • aluminum driveshaft
    I bought a driveshaft off ebay he said that it came of a 95 T56 camaro. this is the aution http://cgi.ebay.com/ebaymotors/ws/eB...tem=2459065255 .I have a 2000 3.8 camaro automatic. I tried to install it but the ujoints in my car are smaller. how do I find the correct u joints or how can I use this drive shaft.
    2000 convertable Camaro White <br />3.42 LSD<br />9.45 1/8<br />8.72 1/8 NOS<br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/Suspension/driveshaft_loop/driveshaft_loop.html\" target=\"_blank\">Driveshaft Safety Loop Guide + prices</a><br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/braking.html\" target=\"_blank\">Line Lock Guide + Prices</a><br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/rearend/rearendcoversupport.html\" target=\"_blank\">Rear End support/girdle/cover Guide + Prices</a>
    sorry I posted it in the wrong area. first time posting sorry
      You might have to buy two U-joints. One with the correct cup (end cap) size for your yoke and the other for the correct cup size of the driveshaft. If the IDs of the cups are the same (which they should be) you can use two cups from one onto the other.
        You should be able to replace the rear u-joint without too much concern. Take it in the NAPA or one of those places and they should be able to tell you what you need and press it on there for you too. Probably cost you about 30 bucks or so. I'm surprised the ds sold for 150 needing a new u-joint.
        - JT3<br />1998 Red V6 Camaro Y87 Y3F - J.E.T. Chip Stage II - Clear Parking Lights - Removed Grill - K&N - Whisper Lid - !FRA MOD - MAF Screen Removed - Pro 5.0 - Pacesetter Headers - Magnaflow Catback - 32mm Front Swaybar - And A System(bump bump)
