Help with removing door panels! - FirebirdV6.com/CamaroV6.com Message Board
  • Help with removing door panels!
    For some appearance mods, I need to remove my door panels. I noticed a screw in the magazine holder. I take it that needs to be removed, after that what other screws need to come out?
    Edit: The car is a 2001 firebird.
    [ May 02, 2002: Message edited by: Houston F-Body ]</p>
    01 Firebird <br />Whisper Lid - K&N<br />Raised Air Lid - Free Ram Air<br />Borla Cat-Back Quad tips<br />3.42s with lsd on the way
    Search the panel for about 5-7 screws - some are BIG and some are small - 2 sizes only.
    Once you remove ALL the screws pop out your electricl door/control panel if you have electric stuff - otherwise pop off the spring holding on your windowcrank [img]smile.gif[/img]
    Then, pull up and out gently on the door panel - if something snaggs - unscrew it or pop it loose.
    Be sure you remove the door handle/lock cover and upper triangle before removing the panel - goodluck.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      it sucks trying to put it back on once you have it off..
      IT REALLY sucks and trying to keep the lock mechanism arm lined up right and everything.. a major pain literally too
      Lots of L type arms holding the door on.. you have to roll down the window and look down the top side and just start working one end loose at a time
