Installed Chevy Mudflaps for appearance, gave her some gas to get out the way of a car, The RPM's got up to 3 - 4Kish but, I was still doing 30 MPH in second gear, It seems like I should have been going close to twice that fast...
Do Mudflaps create THIS much drag???
RPMs are directly related to speed. In a given gear, the same speed will always result in the same RPM.Matt
1998 Mystic Teal Camaro M5
Never knew that...
What if you're going uphill at 70 MPH and you don't drop a gear? The engine won't work harder to accomidate for the extra resistance? or the RPM's won't SHOW that the engine isn't working harder to accomidate for the extra resistance to maintain 70 MPH?1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
RPMs only show how fast the engine is turning. You open the throttle more, which allows more air to enter the engine, which results in more power...but the engine is still turning at the same speed.Matt
Originally posted by 98Camaro3.8:
RPMs only show how fast the engine is turning. You open the throttle more, which allows more air to enter the engine, which results in more power...but the engine is still turning at the same speed.1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
If you had a 5 speed, it may be time for a new clutch... do this simple test. Get on level ground... get the car to 25 mph put in third gear and gun it, if the rmp's go up before you increase speed, it's time for a new clutch. If you have an automatic then I dunno, somebody w/ an auto would have to help ya. Hope this helps.\'97 Camaro 3.8L
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
