Misfire diagnosis part 2 - FirebirdV6.com/CamaroV6.com Message Board
  • Misfire diagnosis part 2
    Ok guys I've determined a lot of things in trying to diagnose my misfire. A run down on the problem again is as follows.
    My car is misfiring on random cylinders mostly from 1500-2500 rpms under load. It perfroms well at lower speeds and if it is in higher rpms like around 3000. There is a small amount of misfire if I rev it up completely but barely any.
    Now, this is what i'm figured out.
    1. I don't think it's a fuel related problem (pump, filter, injectors) there seems to be no loss of fuel and it doesn't have a hard start of seem to be running lean.
    2. It can't be just a plug or a wire because it is misfiring on random cylinders. I'm pulling the code P0300 (Engine Misfire Detected).
    3. I replaced all 3 coil packs and still nothing.
    Now, i have a few theorys...
    I think it has to be the crank shaft position sensor or the ICM. Those are the 2 components that control the coil packs. But the crank shaft seems like a hard install to just throw a part at it and see if it works. I can test the ICM. But I'm wondering what you guys think about the situation.
    Thanks, Ted
    thanks agian guys? really, i'd like to thank you for all the help you guys have been providing
      check your intake manifold doesnt sound liek it buy i would check it otherwise maybe the pcm
      - Why tiptoe through life to arrive safely at death -
        <blockquote>quote:</font><hr>Originally posted by Ted:
        thanks agian guys? really, i'd like to thank you for all the help you guys have been providing<hr></blockquote>
        [img]graemlins/rofl.gif[/img] I will check it out sat man.
        2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
