Is this the one u gotebay #2459630826 CARSOUND CATALYTIC CONVERTER HIGH FLOW ?
What can I get for my car that would be the biggest intial performace upgrade
man, for the styling and the power, i'd go with a qtec electric cutout on the y-pipe. only thing, it won't pass inspection so this might not be an option. the cutout is super loud so the electric opener/closer is bad *** because you only hit a button and it's instant quietness...
second is a 160' thermostat, i haven't had any problems with mine, works bad ***.
third is intake, get a hammer or wrench and smash all those fins off the inside of your lid, an piece of 3" pvc pipe to run from the lid to the TB. Then, get a wizard and remove the bottom part of your airbox, take the wizard and cut out the bottom inside plastic so that the cross section and the sides are gone and when it sits back where it came from you can see the shroud. now cut 1-2" down toward the ground from that slit in the shroud and go across, joining the slits together and making a hole in the shroud.
after that, if you want to, you can get some sort of flat plastic or metal object to slide in over the a/c condenser. this makes a huge difference, have you ever stuck your hand out the window of a car going 70? that much air just about supercharges your ride at high speeds and the power just keeps multiplying. all this should cost $0
posted by 98 v6
"after that, if you want to, you can get some sort of flat plastic or metal object to slide in over the a/c condenser. this makes a huge difference, have you ever stuck your hand out the window of a car going 70? that much air just about supercharges your ride at high speeds and the power just keeps multiplying. all this should cost $0 "
Mabey i just having a brain fart at the moment how does this work???1998 Navy Blue A4 Camaro (Sold)<br />MODS: Performance<br />Whisper airlid,K&N Filter, TSP Rumbler & Carsond cat.<br />Apperance:Xenon Airdam and clearcorners. <a href=\"http://www.cardomain.com/id/wilkcamaro98\" target=\"_blank\">http://www.cardomain.com/id/wilkcamaro98</a><br />2002 Dodge Ram Sport Silver 4.7 v8 stock.
Anybody wanna think about gearing? The 3.42s will give you a big gain in the quarter mile over the 3.08s...Tom<br />Too many mods for this sig.<br /><a href=\"http://www.l337server.com/Tom/cars.html\" target=\"_blank\">My car\'s site</a><br /><br /><a href=\"http://www.FullThrottleV6.com\" target=\"_blank\">www.FullThrottleV6.com</a>
your speedo will be 10% off and you should pick up .20 or sowww.turbov6camaro.com
1997 3800 Series II Camaro
What bout a cat converter? What kind u guys think? And what bout ones with SINGLE 02 BOSS or dual? Check out this site on ebay to see: http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWA%3AITThe mods: Flowmaster 3\" catback exhaust system, K&N Aircharger Intake Kit, Polished 077 Eagle wheels and more to come.
:D
A catalytic converter is just part of your exhaust system... you'll notice no difference in your quarter mile time by changing out your cat.
Replacing the entire exhaust system (including intake) would be a good way to start, yet it is pricier than some other mods that would get you going faster.
[ February 23, 2004, 07:07 PM: Message edited by: RancidCamaro ]Tom<br />Too many mods for this sig.<br /><a href=\"http://www.l337server.com/Tom/cars.html\" target=\"_blank\">My car\'s site</a><br /><br /><a href=\"http://www.FullThrottleV6.com\" target=\"_blank\">www.FullThrottleV6.com</a>
What do you think would be cheaper? I got a flowmaster catback exhaust. I wanna get a cat converter too but i am not sure what to get a single O2 Boss or a Dual?The mods: Flowmaster 3\" catback exhaust system, K&N Aircharger Intake Kit, Polished 077 Eagle wheels and more to come.
