Blown head gasket - help - FirebirdV6.com/CamaroV6.com Message Board
  • Blown head gasket - help
    Well im pretty sure i have a head blown gasket. It leaks anti-freeze a lil bit and leaves drops under neath the car after it has run for awhile. Takes about a month for the radiator to completly empty(which i dont let happen). Yes it is coming from the head gasket.
    Oil is fine, nice and clean. Car runs perfect with no funny sounds. It just leaks a lil anti-freeze everytime the car is run.
    Dont have the money to replace the headgasket now so what are the best products that help to stop it?
    1994 firebird red t-tops 115K miles. needs paint job badly<br /><br />1993 camaro - gone<br /><br />1995 camaro - rdy to be drivin :)<br /><br />1987 camaro - slow *** v8 - blew it up ha
    You sure it's not just a bad water pump? If it is indeed a BHG, I'd also suggest getting your heads checked over from cracks. I cracked a head with 85,XXX and my car was like yours, ran fine and leaked a little antifreeze.
      Its deff not the water pump. The anti freeze leaks between the water pump and below the thermostat. Trickles down the lil groove between the braket which u need a flashlight to see.
        by what you said, it doesnt sound like a bown head gasket
        2000 3.8 A4 Pewter Camaro
          What could it be? the head?
          No hoses leak
          Water pump is fine
          Trickles down between the grove between the braket where the waterpump/thermostat sits
          Car runs like its new
          Oil is clean
          Smokes a tad but its hardly noticible
            sorry to say, but sounds like cracked head.
              if its behind the water pump hows about front cover?
              I will take on all comers...or come on all takers!!! Whichever you prefer.
                How much would it be to replace a head?
                  you can get a used set of heads for probably $50. but unless you do the swap yourself your gonna pay out the a** for labor
                  1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
                    its kinda of hard to crack a head.. i doubt thats it.
                    brink<br />1998 White Camaro 3.8L V6:<br />Flowmaster Exhaust<br />No cat (straight pipe)<br />Free Ram-Air<br /> <a href=\"http://www.cardomain.com/id/98camaro98\" target=\"_blank\">http://www.cardomain.com/id/98camaro98</a>
