alternator problem? - FirebirdV6.com/CamaroV6.com Message Board
alternator problem?
  • alternator problem?
    I drove my car around tonight and everything was fine. I got home and turn off my car..
    I decided to turn it on again for some reason and when i did I noticed that the lights were dim.. I looked down and my RPM's, battery, and electrical things were going nuts.
    It would go from 1000 idle to 1300 idle, from 13 V down right below 12..
    I waited to see if it would die out but it didnt, it stablized back @ 13V and 1000 rpms.
    Was this just a fluke or something..? Maybe i should go try it again.. I felt the plug in he back of the alternator and pressed it in tighter.
    (a few weeks ago-- to make a long story short, to fix an antifreeze leak they had to take it off and when they put it back on they didnt plug it in LOL. so i went back and they did it like 10minutes later)
    Do you think the plug could be slipping/
    3.8L V6 /w 132,000 mi. a lot of miles, time for a new alt.?
    brink<br />1998 White Camaro 3.8L V6:<br />Flowmaster Exhaust<br />No cat (straight pipe)<br />Free Ram-Air<br /> <a href=\"http://www.cardomain.com/id/98camaro98\" target=\"_blank\">http://www.cardomain.com/id/98camaro98</a>
    Go to Autozone and get your Battery and Charging system tested. After you get the results from there see whats up.
    1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
