battery weight...is this a good idea??? - FirebirdV6.com/CamaroV6.com Message Board
  • battery weight...is this a good idea???
    Considering moving the stock battery to the trunk...hehe
    Sound like a good idea? Will there be problems with the gauge of wire or the length of wire I use???
    [img]graemlins/burnout.gif[/img]
    Or am I just a CrackHead?? [img]graemlins/dunce.gif[/img]
    Raised Air Box, Tbyrne Air box, 8mm wires, platinum plus +4 plugs, <br />deleted maf screen, free ram air mod, free/homemade CAI, SS \"fully-functional\" hood, removed weight shit, 93 octane,etc.<br />all to run a best of 14.85 @ 90.88 mph!
    One question:
    Why???
    Mike<br /><a href=\"http://www.my99firebird.gq.nu\" target=\"_blank\">www.my99firebird.gq.nu</a>
      I have seen guys do this to put in a supercharger (well one guy Lol) but if you odn't plan on it I personally don't think its worth the hastle, plus you usually end up putting it where the spare goes and thats just plain silly~!
      RedLineVSix <br />95 Patriot Red Trans Am, M6, 3.42\'s,no rear tires<br />(SOLD!)97 Silver Camaro 3.8 Liter A4 3.42 + LSD, 1pc DS, and one messed up speedo :)
        it's not adding weight, but it's RELOCATING weight which CAN make a difference
          It depends. If you're looking for better weight distribution and stuff, sure, you can do it. Personally, if I was going to do it, I'd get one of those really light Dynabat dry cell battery's and put that in the spare tire compartment. I don't keep my spare tire in cuz I don't drive long distances a lot, mostly within 30 miles of home. Guys do this just to lower the weight of the car for better acceleration, have more weight in the rear for a more blalanced car in corners as well as having better weight transfer to the rear during hard acceleration, so yeah, you can do it and it'll help a little bit, not so much that you'll really feel it, but it is a bit time consuming and you gotta run a bunch of cable up to the engine bay, so it's kinda work intensive.
            I have done it before and it makes a HUGE difference!!!!
            38 lbs off the nose.
            I, at one point, rigged up the battery in the spare tire well and the relocation of the 38 lbs to the rear traction side (right side) really did help.
            This is something I plan on doing again soon and also add a battery cut off switch too.
            When I did it the first time I just rigged it up. I ran lines that were not thick enough and eventually ran into starting problems.
            The nose rises up significantly which improves traction and launching etc.
            Will you go quicker in the 1/4, probably not.
            Will it help your launch, most likely.
              12secv6 ty...finally got a real answer
              Magnus would probably say the same thing as you did
                Instead of relocating my battery, I'm buying a light weight one for about $50.. many people were raving about it on the ls1tech drag racing forum.
                Its about 13 lbs I believe.
                Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
                  way ahead of you, i want to do it but its hard to find time and all that, but here's a link, kinda pricy but i bet if you really wanted you could rig something up your self, and as far as wiring i have no idea use something big though...
                  http://www.bmrfabrication.com/misc.HTM
                  [img]graemlins/thumbsup.gif[/img] to BMR they're badazz...
                  merlin
                  2002 Firebird<br />2003 Yamaha YZF 600R
                    If you do this, it should for sure be a dry cell battery. Wet cell (regular lead acid) give off hydrogen as a byproduct of their chemical reactions. If you put it into a small enclosed area, like a trunk or spare tire compartemet, the hydrogen will build up. Now this is bad, because hydrogen is explosive/flamable. Not only that, but you wouldn't put a bucket of acid in your trunk, would you? Sometimes when lead acid batteries go bad, they can over-flow, over-heat, or explode. Or in an accident it may leak out onto you. So if you do this, you should probably go with a dry cell battery.
                    <a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
                      For a daily driver where the car doesn't see a lot of track or autocross time, I don't see a whole lot of point in doing this mod. It would be cool and definitely benificial if you were racing it alot in competitions such as the tracks, but for normal street racing (if that is what you mainly do), I think your money would be better off modifying another system of the car.
                        <blockquote>quote:</font><hr>Originally posted by Magnus:
                        <hr></blockquote>
                        For $50???
                        Where???
                        One of my local buddies (kerminator) runs 11.4.
                        He has the light weight batteyr in the stock location.
                        It is good for a track only car.
                        At night w/ headlights on or any demand on power and it can't handle it :(
                          Less weight for 50 bucks? I agree... where?? The only one I know that is lighter weight is the dyna batt dry cell, and it's not 50 bucks. He he
                          Thanks, <br />JAM<p>02 Firebird GT
                            kinda off the topic question guys, but do the Orbital batteries weigh less than regular car batterys? I know the big thing with them is that you can mount them almost anywhere and they won't leak acid all over the place, but other than that, are they also lighter?
                              The Orbital batteries that I used to sell where acually heavier than a lead acid battery of comparable size.
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
