ice 32 system???? - FirebirdV6.com/CamaroV6.com Message Board
ice 32 system????
  • ice 32 system????
    Has anybody heard of this stuff. Its supposedly reduces the wear and tear on the compressor, etc because it is a smoother flowing surface place it insulates the insides of the pipes. I was thinking about getting it due to the damn heat wave. Its also supposed to make the AC work better by lowering the temperature quicker as well as the overall temp. Any ideas, concerns, experience with this stuff. The dealership would be installing it and it only takes like five minutes. One more thing is that it contains a dye in it to see if any leaks occur in the past, present of futurs. Let me know what all of you think. Thanks. I supposed to have it installed on friday. Thanks again.
    1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
