I've heard about this stuff called seafoam. Could anyone tell me more about it? Is it good for our cars and how much does it costs? Is it easy for me to use or do I need to go to the shop. Aslo, has anyone ever tried slick 50? I thought about trying that. Basically I just want to do preventive work to my engine and clean it out. Any suggestions?
Engine Cleaning
It's VERY easy the directions for using it are on the can. It is supposed to clean the combustion chamber, clean fuel injetors, you can add it to the crankcase. To use it in the engine you pull off the brake booster vacuum line, with the engine running poor in approx. 1/3-1/2 the can into the vacuum tube then turn off the engine and let it sit for 15 minutes, then start it back up and drive the car, you should see a lot of white smoke coming out of the exhaust.
so will this help the engine a lot..? i mean my car has 132000 mi on it.. should i use this in the engine.. I mean.. does it prolong engine life?brink<br />1998 White Camaro 3.8L V6:<br />Flowmaster Exhaust<br />No cat (straight pipe)<br />Free Ram-Air<br /> <a href=\"http://www.cardomain.com/id/98camaro98\" target=\"_blank\">http://www.cardomain.com/id/98camaro98</a>
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...4 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...6 days ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 weeks ago
