im getting ported heads off of a bonneville... i talked to a friend and he said i would also need a maft+ box too.... first of all how much will it cost to get the heads installed and where can i get the box cheap... should i take off my JET PCM if i do this? Thanks!
getting ported heads off a bonneville
00 Pewter Y87 Camaro-SS Hood/Chrome rims, Black Halos, Clear corners, Pacesetters, V8 K&N FIPK, 3\" B&B TriFlow, HPP3, MSD Coils, Taylor wires, Transgo stage II, Edge 3000 Stall, 180* thermo, SLP Bowtie Grill<br /><a href=\"http://www.cardomain.com/memberpage/468763/1/\" target=\"_blank\">Carro</a>
are they from a series II? If from a series I, probably will not fit then.
Teal99-
you can only use heads off of a NON supercharged 3800 series II.
The heads from a supercharged 3800 II have injector bosses in the heads instead of in the intake manifold.
Double check your compatibility before you spend any money.1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
i'm getting it free.. my friend works at a dealership and he got it for free off a bonneville with bottom end problems... Turns out that it isnt ported though.. the tech at the dealership ported this 2.4l head..
i want to get it ported or port it myself.. I might send it out to someone on the forum who can port it.Mystic Teal Metallic
