Hello, my car seems to vibrate when it is idle. Immediatly after turning the car on it doesnt vibrate, but when stopped at a stop light etc the car vibrates. The idle speed looks normal and isn't jumping around or anything, and if i put the car into neutral or park the idling stop. It feels like the car is trying push against the brake and go... any ideas?
Vibration at idle
is auto, manual, what year, camaro, firebird .. ?? we realy aint psychic , regardless of what you've heardUmmad!<br />2k pewter maro M5. 160 thermo, WhisperLid w/K&N Filter, Jet PCM Stage 2, Free Ram Air, Air Silencer Delete (purchased already and) waiting to install manual fan switch, air/fuel ratio guage.
I have a very similar problem, only i would not say my car feels like it is pushing against the brake and wanting to go.
I posted my problem maybe two months ago or so, and no one could give me any feedback on the topic. In my case it is real minor and it does not do it all the time, but it would be nice to find out what is going on and how to fix it.
I have no idea what it could be. My car is perfectly maintained!
Hopfully we will have better luck this time around.2000 Monterey Maroon Chevrolet Camaro<br />3.8L V-6/4spd Auto
my 94 auto did that same thing.. i wouldnt worry about it.. camaros are old, unless its really buggin youbrink<br />1998 White Camaro 3.8L V6:<br />Flowmaster Exhaust<br />No cat (straight pipe)<br />Free Ram-Air<br /> <a href=\"http://www.cardomain.com/id/98camaro98\" target=\"_blank\">http://www.cardomain.com/id/98camaro98</a>
its tough to say what it could be. I have been trying to fix my rough idle prob for a while now. i have thouroghly looked over at the aspects that cause it, vacumms egr plugs wires rad pressure, intake leaks, filters, .. . . . But i havent checked compression. I believe i my have a compression prob. or valves leaking. But i think my car is new enough to not have those problem yet. 63,000 miles aint bad. but shi* happens so i just deal with it and turn up the volume
But other that that crap, check all you can maybe its something really little like plug gap or something. What have you tried so far?Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
My 95 Firebird did the same thing. I would be at a light and my car seemed like it wanted to go, i would have to press the brake down really hard to fight against it. I changed my PCV valve and my wires and there was no rough idle at all. Car is motionless when i'm stopped at a light (except for the lil' motion from the exhaust). I don't know if that might be your problem or not. If u haven't changed ur PCV valve i'd suggest u do it, cheap and fast.<a href=\"http://www.cardomain.com/id/1995birdman\" target=\"_blank\">http://www.cardomain.com/id/1995birdman</a>
Both my cars do that as well. Come to a stop it seems to idle ruff but the rpms dont vary at all. It doesnt pull like some other have mentiond like it wants to go. Outta all the camaros i have ownd they all have done the same thing when they get old1994 firebird red t-tops 115K miles. needs paint job badly<br /><br />1993 camaro - gone<br /><br />1995 camaro - rdy to be drivin :)<br /><br />1987 camaro - slow *** v8 - blew it up ha
you have a 3.4, get used to it.... I have a 3.4 and a 3.8.... so untill someone has owned both... they dont know "jack schitt"
the 3.4 wasnt very balanced... gm did a terrible job on that motor...
my 3.8, sometimes when its started, i dont know if its running... cant tell....
the 3.4 the whole car rumbles...
although it did start moving a little less when i changed the fuel filter, and a little less when i added lucas to my oil
My 3.4 idles kinda rough too but doesnt miss or anything, as Big Tymer said this engine isnt very balanced however mine is very powerful I think and I kinda like the rough idle...makes me think I have a cam hehe.1995 Arctic White Camaro. 3.4L/A4<br /><br />\"Stupid men make mistakes, wise men learn from mistakes\"
