HELP QUICK!!!!!! - FirebirdV6.com/CamaroV6.com Message Board
HELP QUICK!!!!!!
  • HELP QUICK!!!!!!
    How do I remove the instrument cluster? I've everything except it. i've taken all the screw (i can see) out, but it still seems stuck somewhere and i cannot remove it. I'm trying to install my indiglo gauges. PLEASE HELP QUICK
    <a href=\"http://www.xbox3604free.com/default.aspx?r=381546\" target=\"_blank\">http://www.xbox3604free.com/default.aspx?r=381546</a>
    As long as you have taken all the screw out just pull. there is a plug behind it. it should come out. wiggle and pull.
    1995 black firebird,t-tops,3.4L M5 Comp cam,gutted cat,Cold Air,80 series flowmaster,limited slip rear end with 3.42 gear, Hurst Billet Plus, 17\" American Racin Torq Thrust II
      Make sure you took out the screws for the cluster itself and not the screws that hold the plastic cover on. If you've got it right, it the whole thing should wiggle. If it wiggles, just yank real hard [img]tongue.gif[/img]
      ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
