Fuel Filter Removal - FirebirdV6.com/CamaroV6.com Message Board
Fuel Filter Removal
  • Fuel Filter Removal
    Do I need any special tool to get the fuel filter off? I searched and found a post that said I might need one but it wasn't really clear one way or the other.
    I have a 99.
    SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
    Just two wrenches...the other side is quick release if I remember correctly
      Loosen the nuts and press on the end towards the front of the car with needlenose pliers and it should pop right out. This is the trick I use.
      <a href=\"http://www.cardomain.com/id/kefkafloyd\" target=\"_blank\">http://www.cardomain.com/id/kefkafloyd</a> <br />Red 1997 Pontiac Firebird 3.8L A4 w/ Y87
        Ok, I saw the two plastic tabs on the filter (front side) that make up the quick release. Those are what I was wondering if I needed a special tool for. I will use the needlenose pliers as suggested.
        Thanks!
        • Andy H
          Transmission removal help!!
          by Andy H
        • 2.8 Bird
          Abs inop
          by 2.8 Bird
        • fishin
          by fishin
