tach interface for v6 to v8 instrument panels - FirebirdV6.com/CamaroV6.com Message Board
  • tach interface for v6 to v8 instrument panels
    check out this site http://www.dakotadigital.com/Detail....rtNumber=SGI-8
    and this one http://www.dakotadigital.com/Detail....rtNumber=SGI-5
    My question is would it be possible with this combination of these two pieces and maybe an slp recalibrator or something like that to change the dash for a v6 to a v8 of the same year. I plan on changing the engine to either the ramjet or and LS1/LS6 and I'm looking for options so that I can get correct readouts with having to get extra gauges from autometer or others for stuff like my speed and tach, etc. Let me know what you think thaks for any help. As always any help and info is appreciated.
    1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
    This doesn't realy qualify as advanced tech so I'm moving it to General Tech.
    - Keith
      its the LS6 the z06 engine? cuz if it is you're gonna pay way to much for it because its a specialty corvette engine. I remember looking into getting one a while ago, and its not worth it. You're spending like 4k on the engine... plus theres all the extra stuff to but it in. Its bigger and doesnt use the same tranny. I'd stick with the LS1
        The LS6 is in all 2001+ Camaros and T/A's also. It is simply a different intake manifold and some other odds and ends. The tranny will bolt up to both of them though. The LS6 replaced the LS1 in late 2000. The Z06 engine has a much better cam and different heads that the standard LS6 engines.
        [ July 08, 2002: Message edited by: viper98885 ]</p>
          There is more to the LS6 than just intake.. LS6 has improved heads, different cooling system and 4 bolt mains..
            The speedo calibrator says not to use with ABS Vehicles.
            ~S87 Black 99 Firebird~
              <blockquote>quote:</font><hr>Originally posted by Magnus:
              There is more to the LS6 than just intake.. LS6 has improved heads, different cooling system and 4 bolt mains..<hr></blockquote>
              Really?That sucks because I was told that a kit was sold that would turn my LS1 into a LS6 for like $2k installed.I was told it was only the intake manifold and the cam.Oh well,I guess it'd be better for me to get a different cam/head package anyway......
              Kevin
              PS
              Thanks for the heads up Magnus,maybe you saved me some $$$ in the long run....
              1998 Black Z28<br />1995 Black 3.4 (@#$$%* ex took it!)<br /><a href=\"http://photos.yahoo.com/bc/nikkev1/lst?.dir=/New+Camaro&.view=t\" target=\"_blank\">Pics</a><br /><a href=\"http://www.scfyb.com/phpBB2/\" target=\"_blank\">Carolina Board</a>
                5 days ago
