Got an autometer a/f gauge...where EXACTLY do i hook up the POWER (red) wire? I know its gonna be like the Ignition wire or something cuz you dont want it on all the time. But how do I get it to the ignition wire? I am a little confused on this...
air/fuel gauge, where to connect power?
2001 Camaro A4<br />Maroon Metallic <br />Y87,Monsoon 500w,TTops<br />Appearance: Silver ZR1s w/ 275\'s<br />Intake: !Air Silencer, FRA Mod, k&n<br />Exhaust: 3\'\' Cat, 3\'\' B&B TriFlo<br />Misc: SLP Fan Switch, 1LE Boxed LCAs <br /> <a href=\"http://www.cardomain.com/id/mshapiro\" target=\"_blank\">http://www.cardomain.com/id/mshapiro</a>Tags: None
When I put mine in, I just ran it to the fuse box, and and used the radio terminal. This may not be the traditional way of doing it, but according to autometer tech., AND Fazegauge.com, it is safe to do. What brand of Air/fuel gauge did you get?1995 3.4-Blackouts, 3 10\" MTX Subs, High flow cat, Faze voltmeter & air/fuel gauges Kenwood 800w amp,80\'s series Flowmaster, . ....more to come
Autometer #4375
I think the ground may have been my problem, I should have ran it back into the engine bay, but instead i hooked it up to a bolt under the dash...
I guess I will try again with the power to the fuse box.2001 Camaro A4<br />Maroon Metallic <br />Y87,Monsoon 500w,TTops<br />Appearance: Silver ZR1s w/ 275\'s<br />Intake: !Air Silencer, FRA Mod, k&n<br />Exhaust: 3\'\' Cat, 3\'\' B&B TriFlo<br />Misc: SLP Fan Switch, 1LE Boxed LCAs <br /> <a href=\"http://www.cardomain.com/id/mshapiro\" target=\"_blank\">http://www.cardomain.com/id/mshapiro</a>
I used the radio fuse because it will turn your gauge on when the key is the accessory position, and when the car is running. If it still doesnt work, the problem is with your ground.1995 3.4-Blackouts, 3 10\" MTX Subs, High flow cat, Faze voltmeter & air/fuel gauges Kenwood 800w amp,80\'s series Flowmaster, . ....more to come
i just pulled out the radio and spliced into the yellow power wire..yellow is traditionally the ignition...got it on the first try w/ no voltmeter! [img]smile.gif[/img] gauge is temporarily in the middle driver's vent. BTW....i've got the autometer ultra lite A/F...i have multiple, and i mean ,multiple led's light up...i know it's supposed to be a scan type gauge, but my friends has only like, 2 on at a time, while mine has maybe 5 or 6. it's mostly at idle...does anyone's else's do this? i've got mine hooked into the high wire on the cats O2.1998 Chevrolet Camaro L36 M5<br />1982 Toyota Celica Supra 7MGTE project car - FOR SALE<br /><br />\"I find the most sensual part of the woman is the boobies.\" - Zap Brannigan
