Power Locks - FirebirdV6.com/CamaroV6.com Message Board
Power Locks
  • Power Locks
    Driver side works, passenger side doesn't...nough said. What's wrong?
    Both remote and button on door will only work the driver side...passenger side you have to manually operate it
    TTT
      take the button out of the side of your door. might have broken off. if it did, just glue it back together.
      2000 NBM M6 Camaro Z28<br />323/335
        They are like $5 to $10 at the dealer get a new one. At least they were that cheap on the older ones.
        The relays go bad inside the switch to.
        94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
          I don't get the electronic stuff to well, but if the button is bad on the passenger side, shouldn't the driver side lock still be able to lock the passenger door. You hit the button and I hear NOTHING happening on the other side so maybe it's something mechanical. Either way please explain yourself in English...I'm really retarded when it comes to this stuff. [img]tongue.gif[/img]
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
