Whats the easiest way to install a underdrive crank pulley??? Is there any other way I can install the pulley without sticking a screw driver in the transmission, I really don't feel like breaking anymore expenisive parts of my car. Thanks.
Underdrive Pulley Install
Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....Tags: None
you might be able to use an impact wrench on the crank pulleys, if that wont work or you dont have one , then you have to use the screwdriver in the trans... its not hard, you shouldnt break anything-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
Automatic?
Wasn't a problem on my 5 speed. Put it in 5th gear, pull the emergency brake and go at the bolt with a breaker bar.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
ehh its not that bad...
put it in park or in gear and pull e-brake up. then take each botl off.
hehe it was funny on my 3.4L when I was taking my crank pulley off, I had no e-brake, so I cranked the car in gear about 5 feet, before the bolts came loose [img]smile.gif[/img]
Sim0ply install, I took mine out and put in the stocker in about 20 minutes. And last night the guy I was selling it to, we did it in a parking lot of Sonics, in 15 minutes, and the power went out, all we had were mini mag-lites.
I tried putting it in park and in gear today. I only could get 1 bolt to come off when I tried the rest of bolts the pulley just spon. Any other ideas???Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
yes i had the same exact problem...
Get a crowbar or something to wedge in between the pulley, then have a friend pull the crowbar towards the nose of the car, this puts pressure on the pulley and makes it not move.
You can do it your self just a lot harder to pull on the crowbar while trying to loosen the bolt. Its better if you have a friend there to help you.
Also remove the middle bolt first, then do the 4 smaller ones.
Yeah, i'm the guy who did it in the parking lot. When I took it off, I just too the biggest and longest socket wrench i had, put it on the center bolt, and gave it a couple of good tugs and it came loose. Then, I did the 4 corners. Maybe try spraying some PB blast on it(its a penatrative oil you can get at most auto parts stores) and leave it on there for a few hours before. Makes it easier sometimes. Maybe if your bolts are that hard to remove you should pick up a set of new ones at the parts store, as well as clean your threads out good before you put your new pulley back on.1995 Blue Chevrolet Camaro <br />Dynomax Exhaust, Custom CAI w/K&N, Throttle Body Bypass, ACDelco Plugs/Accel 8mm Wires. Indiglo Gauges. BMR Stut Tower Brace, ASP underdrive pulleys, BF Goodrich g-Force T/A KDW\'s around. <br />AIM: STMIKEK
