A/C acting weird - FirebirdV6.com/CamaroV6.com Message Board
A/C acting weird
  • A/C acting weird
    I have a 99 Camaro with a 3.8 and M5 transmission. I noticed that after long trips (approximately 45 minutes) that the A/C dies. Let me explain this more in detail.
    When I turn the A/C on (max setting), I usually leave the fan set on the lowest setting unless I need a bit more cool air, in which I crank the fan switch up one notch. After about 45 minutes the airflow dies down until it is nothing. If I crank the fan switch up to high, the fan makes a very loud and low hum as if it is blowing, but nothing comes out of the A/C vents. I even checked the defroster vents and felt no air flow. If I turn the A/C switch to off and right back on, it's the same scenario... no airflow. However, when I turn the A/C off and leave it for about 5 or 10 minutes and then turn it back on to max, the air is just as cold and blows just as strong as it did without the problem, but it dies down again within 15 minutes or so. Any idea what could be causing this problem? Since it is so intermittent the dealer where I bought the car from won't look at it. I did notice though that when parked the car drips a lot of water. Could a clogged drain hose be causing this problem? Is there some sort of failsafe thing that if the drainage tray becomes clogged the air vents won't allow airflow? Any help or insight would be appreciated. Thank you.
    -Jeremy
    The water is just condensation. Not sure why it's not blowing though....
    1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
      The water is just condensation, there is no "fail safe". In fact, if your drain holes become plugged, you'll have water backed up in the system and inside the car. Try your fan the same way without the A/C. It sounds like the fan motor may be getting weak and dying when it gets hot.
      <b>Mike</b><br /><a href=\"http://www.cardomain.com/id/mcjoslyn\" target=\"_blank\">2001 Camaro</a><br />Light Pewter Metallic Convertible<br />AU0,A31,C60,DG7,F41,GU6,K34,L36,M30,T82,T96,UN0<p ><b>If it can\'t be expressed in figures, it is not science; it is opinion.</b>
