Has anyone had this speedometer problem? - FirebirdV6.com/CamaroV6.com Message Board
  • Has anyone had this speedometer problem?
    I was driving along today doing about 35mph and when I shifted gears the speedometer went to 0 for about two seconds than slowly crept back up to the current speed. This occurs all the time now whenever I shift to another gear. My ABS/INOP light went on the day before too so anyone know how they'd be related?
    [ August 15, 2003: Message edited by: Flowbee V6 ]</p>
    <a href=\"http://www.sounddomain.com/memberpage/437104\" target=\"_blank\">http://www.sounddomain.com/memberpage/437104 96 Firebird M5</a>
    Ive GOT THE EXACT PROBLEM! Someone please help us out. PLEASE! Im talking exactly. My ABS INOP light is on and now my Speedometer is cutting out then surging back on. WTF!?
    [ full bolt on\'s and blown.]<br />[formerly known as naptown]<br />[just know that im teh man ]
      This sounds like a charging problem. Get your battery and alternator checked out. I would bet that one of the two are bad.
      Since your cars are still running it is probably the battery.
      SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
        it all depends on how long it's been doing this, the alternator may have a loose connection.
        \'94 Firebird, 3.4 M5.<br />Arctic white w/ red anniversary stripe. ASP underdrive pulley set, Magnaflow 2.5\" stainless catback, CAT, Pacesetters, K&N FIPK2, 1000 watt stereo system capped 1F, Eagle Alloys 16\" 077\'s, 180 Deg. Thermo.
          ABS INOP light has something to do with your 3rd brake light bulbs going out.
            Actually, maybe the VSS (Vehicle speed sensor) is going out, dropping the signal to the speedo and making the ABS system confused because it's reading a signal off of the ABS sensor at the wheels, but getting no reference speed from the VSS. Maybe?
            Check out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
              Well I shall check the VSS when I get my car worked on. Im getting a SLP LSD put in this week.
              I will also check out the alternator. My Alternator is stock, but my car only has 51,200 miles.
              Anyone else have some sort of input?
                Mebbe if my diagnosis was correct, you could "repay" me with that nifty LSD ya got over thar? [img]graemlins/naughty.gif[/img]
                LOL, J/K
