I can't seem to figure it out. It only does it when you give it about 1/2 throttle or more and it goes away once the RPMS get above 4k but, comes back when the engine shifts and the RPMS are below 4k. I already put new wires, plugs, and coil packs on the car and have run a ton a fuel injector cleaner in the tank. Any suggestions on what it could be because i am drawing a blank here.
2.8 that misses under load
No codes (no SES light) and it does feel like a studder or miss if you will. You can hear it in the exhaust like one of the cly are not fireing right when he takes off. I was thinking te TPS but i really dont want to throw parts at the thing. Its bad enough i put 90 bucks worth of coil packs on it and it did not take care of the problem. :mad: Thanks for the help tho, anymore suggestions? It is worse when the car is cold and i can't even rev it untill it warms up alittle. It sort of stumbles on its self untill the temp goes past 150.2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
check out the crankshaft position sensor. I had that go bad on my 2.8L beretta here recently. Also replaced the fuel filter too. try those 2 things first. (cost shouldbe under 40 bucks for both) [img]graemlins/thumbsup.gif[/img]1979 Z28 Camaro, 1 of 10,000 Factory 4 speeds. <br />1994 Camaro Sport Coupe, M5<br />Best ET: 15.31@91.5 (25 hp NOS)
<blockquote>quote:</font><hr>Originally posted by camaro28:
check out the crankshaft position sensor. I had that go bad on my 2.8L beretta here recently. Also replaced the fuel filter too. try those 2 things first. (cost shouldbe under 40 bucks for both) [img]graemlins/thumbsup.gif[/img] <hr></blockquote>
Do you remeber why you replaced the crank sensor? I am thinking about replaceing the fuel filter and that will probly be the next thing.2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...21 hours ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...3 weeks ago
