If i were to get the Jet Stage II chip would i have to change my thermostat, and would i have to run 91 octane gas?? My car is a 99bird, what temp thermo do i even have?? What should i get if i have to change it??
With the Jet Stage II do i HAVE to ......
99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>Tags: None
why couldnt i run 91 octane??99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>
Yeah, 91 is fine. No pinging, but 93 feels a lot better. I don't know why, maybe the 2 ticks on octane make a difference. At least get the 180 degree thermo. Your car will run hotter. Not difficult to change at all. You might lose a cup of antifreeze. Takes a whole 10 minutes if that.<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
You need the extra octane to keep your knock retard from hurting your performance more than the Jet Chip supposedly helps it. The Jet Chip is suppose to add hp by advancing your timing. It's been said that the MAF Translator is a much better mod but requires some testing to make it work right. You might already have a 180* thermostat, my roommate's manual for his 99 bird says he has a 180. I think mine was something weird, either 190 or 195 but had a little hole in it with a bearing held to partially block it, I've never seen anything like it and have no clue what it's for.1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
