Im doing a differential fluid change and im making a gasket out of RTV silicone. Im not sure if i should let it dry or not before i put the differential cover on. Ive heard both put it on wet and dry and im not sure which i should do.
Differential fluid change
Install wet, it tells you on the tube. I use a combination of RTV and paper gasket and it makes a really good seal.
g2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
First off i recommend a gasket with a little silicone on both sides. I did mine late on a sunday and was forced to use silicone. I put it on both the cover and diff, i let it sit for about 10 mines while i cleaned up and took a quick break. I put it together and allowed it to sit over night, then added the oil and so far a few months down the road no leaks [img]smile.gif[/img] .<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
dont install the cover OR ANY part on top of hard silicone. can you say CRACK! as you torqe somethimg against a hard gob of goo?
cure overnight then fill fluids.
