AC help - FirebirdV6.com/CamaroV6.com Message Board
AC help
  • AC help
    I am sorry to have to ask this question, but I am traveling and don’t have access to my manuals (yes I have my car). What pressure should the AC system be? I noticed it was not as cool as it usually is, and connected the scanner and the pressure was at 133…..
    Please let me know ASAP. Thanks
    Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
    I'm assuming that's high side pressure? or is it low side with the system off?
    High side while system is running should be around 200-215. If you measured it with the system off, you'll have to look at a temp-pressure chart to see if it's about right. My gauges show the chart but I don't have them with me.
    1995 Firebird 3.4L<br /><a href=\"http://kansas.no-ip.com/\" target=\"_blank\">My Site</a>
      Actually that was the pressure with the AC on High and the pressure reading was what my Autoscanner (code and sensor scanner/computer) told me.
        was the compressor running when you did this? It will turn off when the pressure gets too low which may explain the reading you have.
          I was driving at 75 MPH so I could not check....I turned off the AC and ther pressure dropped to 119, then when I turned it back on it went back up to 133
            hmmm...well that baffles the heck out of me, I didn't know the computer had the pressure info reported to it, thought there was just a switch in the a/c system.
