Crazy noise coming from rear diff. - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • Crazy noise coming from rear diff.
    I was driving the other day and noticed a new noise coming from my car. I have a 5 speed V6 3.8. Its a rotating/churning noise it increases and decreases with acceleration. even when i role in neutral i hear the same noise as it is in gear. AT 65 in 5th it is louder than the radio. A buddy of mine said it might be my gears going bad? What do you think. It is coming from the rear. I also had a new clutch put in about a month ago. Thanks Coleman [img]graemlins/burnout.gif[/img]
    <a href=\"http://members.cardomain.com/99gatorbird\" target=\"_blank\">http://members.cardomain.com/99gatorbird</a><br />99 Ram Air V6, 18\" Z06 Rims, WS6 Ram Air Style Hood and Lower airbox, Center Force Dual Friction, 3.42 GM Gears, Zexel-Torsen LSD, Free Mods, Dynomax Ultra Flow, Custom Interior, Several Decals from firebats cave<p>9/14/03<br />1/8- 10.45 @ 66.72<br />(I know i can do better)
    Do you have a limited slip?
    Have you changed your diff fluid recently?
    I would recommend starting with a differential fluid change. Go with a good synthetic, I think Valvoline makes some. When you pull the diff cover off see if you have significant metal flake inside the housing. If you do you're grinding gears. See a mechanic.
    2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
      i'm going to move this to drivetrain, i'm sure you'll get more/better responses there.
      2011 Camaro LS 6M, in black.
