so im pretty pissed. one shop says nothing is worng with my brakes the other says i need my rotars turned. ive been having a squeek and now it looks as if all my rotars are rusting or have a lil rust like film on them. now why in the 2-3 years i have had my car it decides to do it now and what is the problem? any sugestions or answers?
2000 pontiac firebird by the way
2000 Firebird 3.8 stick,25%tint, exhaust, chrome Z28 rims wraped with Pirelli Super Sport 245/50 ZR16\'s, JL15ws3 sub powered by a 1400W BOSS RIP-695 amp, free ram air mod, raised airbox
Usually a squeak is caused by the indicators on your pads, could be caused by just dust as well. How many miles are on your pads? If it's less than 20k I'd say they are probably still OK. As far as needing your rotors turned; do you have any vibration in the steering wheel if you hit your brakes at high speeds, 65mph? If you don't then your rotors are probably fine as well. They could be grooved but you can check that just by running your finger over the face of them.Some places tell you that just because they don't think you will know any different.
Rust on rotors is common. Mine will rust overnight if it rains or is really humid out. It quickly gets knocked of the rotor face by the pads when I drive it though.
If you are getting a squeak you could replace just your pads, they're not that expensive.
<blockquote>quote:</font><hr>Originally posted by John D.:
[QB]Rust on rotors is common. Mine will rust overnight if it rains or is really humid out. It quickly gets knocked of the rotor face by the pads when I drive it though.
QB]<hr></blockquote>
Same with mine, might be a GP thing ;)
oh yeah, what he said.
2013 Ram 1500 Big Horn
94 comero 3.4
well i replaced my back brakes maby 1k ago but not my front. i was told my fronts looked ok but maby that was some "mumbo jumbo." The jerking is a def yes. do yall think it would be in my best intrest to just go ahead and buy slotted or drilled rotars and get them put on insted of doing this hole rotating busisness? How cost effective would this be? im on a limited budget being 18 with a kid but if its not to much I would like to give it a try. advice requested and appreciated
-Brandon-
<blockquote>quote:</font><hr>Originally posted by John D.: Stock rotors are all you need. Don't waste your money on slotted/cross drilled rotors they are for looks more than functionality.<hr></blockquote>
Unless you are doing some hardcore autocrossing, this is basically true. I would suggest getting some new pads (Performance Friction) and have the rotors turned and you'll be okay.
yep, theyre a waste of money unless you want the looks. crossdrilled are a compromise for race cars that do a lot of high speed/ hard / frequent braking... they are actually slightly less efficent at one time stops at normal speeds.
