Help SES light - FirebirdV6.com/CamaroV6.com Message Board
Help SES light
  • Help SES light
    For some reason my car keeps throwing the code for incorrect purge flow. If I clear the code it will come back the next day. I just changed the evap. pressure control valve and still get SES light. Just wondering if any one else has had this problem. Any ideas on what it could be. Gas Cap? Bad Fuel? Thanks a head of time.
    1997 3.8(Y87) T -Tops,Auto-3.42\'s,17x8 Eagle 211,Kenwood DVD/Cd 911,SLP CAI,160 Thermo,<br />Borla Cat back,RK sport headers,3\'\' Ran. Tech Cat,Fan Switch,taylor 8mm wires,1p alu. driveshaft,transgo stage 2 and more.
    It's probably the high flow cat. I know it's still a cat but I have heard of people having that problem with High Flow cats. Have you looked into getting an 02simulator? That's what I have and....well...I still get the light but that's cause I'm running with no cat. It should work for you.
    Here is a link to summit's page:http://store.summitracing.com/defaul...t=o2+simulator
    You can get them cheaper from Jeg's but I couldn't find the link. anyway I think it's part#CEI-104033. Hope this helps
    \"I\'m going to torment you beyond the end of time, and hit you with a steamroller!\"
      I dont have the high flow cat on at this time. So I dont believe that its my cat. Any one know of any other possibities? Thanks
        same prblem went away when I chnged the wires (spark plugs)
        97 Camaro RS
          Sorry to bring up an old topic, but does this really fix the code 0441 incorrect flow during purge?
          Or is there some other fixes I can apply that are inexpensive. Any help is much appreciated.
          ~Jeffrey 2004<br />\"Your bark is only as good as your bite! BITE HARD!!\"<br /><br />\"I see your `SCHWARTZ\' is as big as MINE!\" - Dark Helmet, from \"Spaceballs!\"<br /><br />Have you had your *** kicked lately? If not, come see me for an ***-kickin\'!!
            5 days ago
