I have a 98 Camaro and the air conditoner only blows from the floor vents. The air is still cold but will not blow from top vents. Has anyone had this problem?? How do you fix it. Vacume Hoses?? or pump?
A/C Not Blowing Through Top Vents
Similar problem on a friend's 2000 was broken vacuum check valve -- caused vacuum leak & loss of vacuum to AC controls. Default w/ no vacuum puts air to floor & defroster vent only.
Located pass side under hood near front of AC evap core box.
Original check valve made out of cheap black plastic that disintegrated.
New valve ($1.50 at dealer) was different plastic (yellow/white body), same as my 2002, looks stronger than old one.2002 Camaro Coupe<br />Navy Blue, A4, Y87<br />Whisper Lid, Raised Air Box<br />SLP Bow-Tie Grill, HPP3
I had the valve go out on me too, but maybe it was a different one as mine was like 16 bucks from the dealership.AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
I kinda have a similar problem but the opposite. I found my vacuum lines that run by the PCM off, and my A/C has never worked since I got the car. Me and a friend replaced all the vacuum hoses to where they go. (We looked off my friends T/A) The problem is there isn't enough vacuum to kick open the vents that blow towards you, it only blows out the top and bottom. I think I have a leak somewhere back there because I held my thumb over the vacuum hose and you can hear it leak a little. By the time I get it fixed, summer will be over, lol.
Re: A/C Not Blowing Through Top Vents
Ex-5.0, you solution solved my problem of the air only coming out heater/defroster vents with your suggestion of a 3 way check valve.
THANK YOU! You are so awesome, I was about to take it into a shop before I read your suggestion. Wonder how much they would have charged me to replace the hood and replace a <$5 part.
hmmm been having the same problem for about a year. I will have to check this out. how much was the valve modulation? and did you get it from a regular auto parts store?95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
I got mine from NAPA online. I have a 1994 year camaro, and the part is located right next to the computer, close to the firewall where hood pnematic arm mounts.
Item: Check Valve - Universal One Way Vacuum
Product Number: BK 7301348
Quantity: 1
Price: 2.69
Core Price: 0.00
Total Credit: 2.69
Can someone give me a picture as to what needs to be replaced? I have the same problem, when my A/C is set on the vent and floor setting, it sometimes blows through vents, but on any other setting (including "MAX and A/C") it only comes through defrost and floor.
My driver side floor vent won't blow cold air or heat. Is it the same problem?<a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
