Tech advice on my legend - FirebirdV6.com/CamaroV6.com Message Board
  • Tech advice on my legend
    Last friday we were driving the legend when it overheated and died, I check the fluids often and thought maybe a hose came off or something so we got it home and the coolant was low but not out enough to overheat it and i refilled it anyway and it ran fine with no overheating but since then I can start it and it will run and drive fine but whenever i stop the car the rpms will drop to nothing and the car will die, it will start back up fine and drive fine but when i stop it will die again the same way. Ive checked and no hoses are loose, its not overheating and i have no engine lights or anything on and all the fluids are clean and fine. Anyone know whats going on? I was thinking fuel pump but that would make it no run at all
    Dont call me chief.<br /><br />2001 Camaro Convertible Rs Replica<br />1991 Acura Legend
    Maybe you just need to turn the idle up. How does it idle after startup or in park? My old eclipse used to randomly die like that and I turned the idle up. Never died afterwards and it only idled about 100rpm higher than usual after startup.
      it idles at like 700 on starup and 500 in park
        def turn the idle up...i use to work at acura and we'd get those problems a couple times a month
        87 Firebird RIP
        96 Camaro RS RIP
        94 Patriot Red 1LE Z28 - Sold
        02 WS6 TA - Sold
