Brake Lights trouble ! Need help - FirebirdV6.com/CamaroV6.com Message Board
  • Brake Lights trouble ! Need help
    I sold my camaro next sunday (for a vette)
    I've passed the inspection...
    My brake lights aren't working anymore!
    the camaro stays outside for 3 mouths without running
    any idea?
    Where is located the brake light switch?
    99\' Camaro M5 3.23 LSD<br />-SLP CAI,K&N,Whisper Lid,!MAF Screen<br />-2\'5 Flowmaster Catback <br />-BMR STB<br />-Kumho 712 supra 245/50/16<br /> <a href=\"http://www.camaroV6.fr\" target=\"_blank\">http://www.camaroV6.fr</a>
    I've found the brake light switch, it's working great...
    hum...anyone has a wiring diagram?
      do the lights function at all? if you turn your parking lights on, do they illuminate?
        yes...parking lights, turn signals are working...
        it's just the 3 stop lights which aren't working...
        it is the same fuse?
          no, i think the center high mount third brake light has it's own, but i may be mistaken.
          check your fuses, and then the bulbs. the brake lights have a dual element bulb and it's easy for one element (the stop lamp) to break and have the other (park) in good working condition.
            the bulbs are good
            what is the number of the fuse ?
              if all three of them are out, I believe there is a wiring harness behind the "CAMARO" piece that has all the brake lights go through it. And from my experience, when a fuse blows. Replacing the fuse isn't usually the solution. There's something else that you need to look at.
              I had replaced the light bulbs in my car once and accidently wrapped a wire around one of the bolts that holds the light fixture on, it kept shorting out on me and that was the reason.
                Yes!
                It was the swith which was grind!
                it's working!
                thank you all!
