How exactly does everybody calculate their gas mileage. I usually just top off and reset my odometer and check how many miles i get per 16.5 gallons of gas.
calculating gas mileage
Britney Spears is the HOTTest girl in the world!<br /><br />2000 Camaro 3.8L Y87<br />Flowmaster 80 American Thunder catback<br />Magnaflow Carsound Catalytic Converter<br />SLP Ram Air Cold Air Intake<br />Whisper Lid<br /> <a href=\"http://www.cardomain.com/id/freestylin59\" target=\"_blank\">http://www.cardomain.com/id/freestylin59</a>Tags: None
when your tank is full, hit trip odometer...
drive around.
next time you put gas in the car, you see how much gas the pump reads when you top it off.
lets say you made 285 miles, and you just pumped in 13.5 gallons.
so 285/13.5=21.11111 mpg
thats as close as you will get... problems with this...
if your tire size is not factory, or you swapped your gears, your odometer won't read correctly.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
